Are there any pieces from a convertible f-body that can be used to tighten up a coupe? I remember, back in the 60s, factory race cars - like 63 Z-11 Impalas - sometimes used x-members from convertibles to stiffen up the coupe frames. When I've looked up subframe connecters and such, I often see in the description 'except convertible'. There's obviously some difference, any factory parts like x-members, crossmembers, subframe connectors, etc. that would bolt onto my 93 coupe?
Tightening up a coupe with convertible parts?
Re: Tightening up a coupe with convertible parts?
There are subframes you can buy.
http://www.jegs.com/p/UMI-Performanc...71012/10002/-1
Thanks 2.8 bird for the link. Yep, I'm familiar - I spend lots of happy bathroom time reading my Summit and Jegs catalogs. The reason I was asking - I was at my local u-pull-it junkyard (trips to the junkyard always make me happy in pants! :D ), they have a 95 convertible there. If I can get a factory piece that bolts in as opposed to a 500 dollar piece that welds in... I'm sure I'll be going the strut brace/subframe connectors route eventually, but while there's a convertible available, just thought I'd see if there's anything I could use.
Originally posted by wildbill59 View PostAre there any pieces from a convertible f-body that can be used to tighten up a coupe?
1) the K-member is reinforced
2) the trans mount cross-member and tunnel braceLast edited by FirebirdGT; 09-27-2014, 09:42 PM.Robert - owner www.FirebirdV6.com "Mid-life crisis? I'm way beyond that!"
Raven
Originally posted by fbodyrs96 View Postwhat car did that second brace come off of? mine doesn't have it. an whats the differences in the k member, never really noticed them.
The conv K-member has internal bracing, and the external bracing rods.
Raven
Now that's what I'm talkin' about. Thanks, FirebirdGT - lovin' that tunnel brace! I'll be off to the junkyard today. A couple of quick questions: 1st, My car is a 5-speed, should that tunnel brace mount to a manual crossmember, or could I even use the auto piece with a manual trans mount? And second, that k-member - is it just reinforced with those two rods, or is the whole k-member beefier? Thanks again, this is exactly the info I was looking for!
Originally posted by wildbill59 View PostNow that's what I'm talkin' about. Thanks, FirebirdGT - lovin' that tunnel brace! I'll be off to the junkyard today. A couple of quick questions: 1st, My car is a 5-speed, should that tunnel brace mount to a manual crossmember, or could I even use the auto piece with a manual trans mount? And second, that k-member - is it just reinforced with those two rods, or is the whole k-member beefier? Thanks again, this is exactly the info I was looking for!
Raven
Excellent, thanks! Tell me, will all f-body convertibles have this setup, or just Z/28 and 1LE cars? The car at my junkyard is a V6/auto (didn't get a chance to get to check it out today), I'm really hopin' it has that crossmember/x-member like the one in your garage!
Originally posted by wildbill59 View PostExcellent, thanks! Tell me, will all f-body convertibles have this setup, or just Z/28 and 1LE cars? The car at my junkyard is a V6/auto (didn't get a chance to get to check it out today), I'm really hopin' it has that crossmember/x-member like the one in your garage!
.Last edited by FirebirdGT; 10-01-2014, 06:31 PM.Robert - owner www.FirebirdV6.com "Mid-life crisis? I'm way beyond that!"
Raven
by Andy HIts been a while since I've been on the forum. Hope everyone is doing well. I still have my camaro! Unfortunately, the slave cylinder and clutch has went...3 weeks ago
been a while but looks like i'm back in the game thanks to my brother. he went and bought an'02 bird, and since i'm a technician at the nissan place...3 weeks ago
