Im going to replace my Heads tomorrow on my 3.4L... How long does the job take if I want to change the heads out?... Is it hard to do? What am I looking at here? They told me that my intake manifold gasket was leaking and that my heads are warped. Oh yeah and when I put the gaskets back on what side of the gasket do I put the silicone on? And should I use blue or black... I think the Manifold gasket came with black but I dunno about the head gasket
Head Questions for the 3.4L 965-4082
Re: Head Questions for the 3.4L 965-4082
http://www.ls1.com/forums/showthread.php?t=126636
Here's a thread that will have a lot of helpful info for you. I just did a head job on my 3.4 this past december, and it took a total of about 6-7 hours of work. Although I was only able to work on it for 30 minutes to 2 hours at a time. Just remember to keep all your bolts, nuts and everything separated and labeled.
its highly recommended that you get new head bolts. They are stretched for the final torque rate and cannot be stretched again, thus making a head gasket fail much more likely.
Originally posted by Bandit127 View Postits highly recommended that you get new head bolts. They are stretched for the final torque rate and cannot be stretched again, thus making a head gasket fail much more likely.
Originally posted by davidlb512 View PostWow dude! Nice call! I'm sorry I forgot to bring that up. That's the reason I had to do a head job in the first place. Because the original head bolts were reused on a previous head job just before I purchase the car.
NAPA, Rockauto etc etc.
I'd like to know if ARP makes studs, but I havent found any yet.
okay so they guy who was supposed to help me do this clearly hasnt shown up yet n we were supposed to start hrs ago. Im thinkin abt goin in n tryin to change out the heads myself..... is it a hard job?
tomRs did one not to long ago i believe...do a search for the thread.
wow, i typed in "3.4 headgasket" and this was the first thread...
http://forum.camarov6.com/showthread...3.4+headgasket
too easy private. use the search functionLast edited by flamingchicken; 05-12-2010, 08:14 PM.Team NoVa
Originally posted by Bandit127 View PostNo problem! Theres a ton of sources for these bolts too.
Well guys lemme ask how can I tell is the heads are good. I bought a set of heads from a guy that he said he'd had machined but ended havin to buy a new engine because his block had so many cracks in it. He was supposed to help me install them and no he won't answer and i'm kinda scared the heads arent worth anything... Can anybody help
A generic test for it would be to take a level or straight edge, and put it against the side of the head that contacts the block. Place the level in several different directions on that side too, because there are several different ways that it can warp.
Now with the heads I have sitting in my car I noticed that the little pieces that go over the valve springs have a little play in them.. Is that normal? And if so where should I place them exactly during instalation? Or should I jst let them be?
Originally posted by ThaDyce17 View PostNow with the heads I have sitting in my car I noticed that the little pieces that go over the valve springs have a little play in them.. Is that normal? And if so where should I place them exactly during instalation? Or should I jst let them be?
by Andy HIts been a while since I've been on the forum. Hope everyone is doing well. I still have my camaro! Unfortunately, the slave cylinder and clutch has went...3 weeks ago
been a while but looks like i'm back in the game thanks to my brother. he went and bought an'02 bird, and since i'm a technician at the nissan place...4 weeks ago
