tiny tuner - FirebirdV6.com/CamaroV6.com Message Board
tiny tuner
  • #16
    Re: tiny tuner
    thank you
    2002 SOM Z28 Camaro - 12.9 @ 104 mph
    1996 3800 Camaro - 13.43 @ 100.77 mph
    Project Cars | How To Guides | Scratch Repair | Synthetic Oil
    • #17
      Re: tiny tuner
      so you have to have the hp tuner before u can even use the tiny tuner?.
      • #18
        Re: tiny tuner
        hp tuners or DHP only because it is an editor only and you need something to be able to write it in with.
        The thing with Tiny tuner though is it's free, and gives you many more options that the latter of those two tuners don't. So when you use it in conjunction with them, you have 100x as many options.
        • #19
          Re: tiny tuner
          anyone got a bin for an '01?
          auto, aluminum driveshaft, Fast Toys Ram Air, !air silencer, smoothed lid, Pacesetter shorties, 2 1/2" exhaust, !cat
          New Time:
          15.11@91.14
          Team 3M Mafia
          New Times coming soon
          • #20
            Re: tiny tuner
            post on hp tuners or on club GP...those guys have bins kicking around...apparently DHP saves files as BINs...do note though that if you have hp tuners, whatever changes you make on hp tuners wont be read by tiny tuner...you'll have to make all your changes on tiny tuner, and only write them to your pcm using hp tuners.
            • #21
              Re: tiny tuner
              alright thank you!
              New Time:
              15.11@91.14
              Team 3M Mafia
              • #22
                Re: tiny tuner
                Subscribing right now! Anybody selling a HP Tuners setup?
                • #23
                  Re: tiny tuner
                  that'll be a tough one to find...I think I saw one for sale on LS1tech a week or so ago though.
                  • #24
                    Re: tiny tuner
                    does anybody know if tiny tuner has the ability to let us turn on PE vs MAP?
                    • #25
                      Re: tiny tuner
                      under PE there is
                      Base PE A/F vs ECT
                      PE A/F vs TPS
                      PE delay vs TPS
                      PE enable cylinder mass air vs RPM
                      PE enable mass air thresh. Hysteresis
                      PE enable TPS
                      PE mass air enable thresh modifier vs baro
                      PE mode delay RPM
                      PE rpm vs Time A/F
                      what are you trying to do?
                      • #26
                        Re: tiny tuner
                        i would just like to enable pe by map and tps... looks like a few of those could do that. i can't seem to get a bin for it though
                        • #27
                          Re: tiny tuner
                          post on club gp, someone there will be able to do it for you..why enable it through map? TPS should meet all your needs?
                          • #28
                            Re: tiny tuner
                            I Did make a post on 3800 pro and somebody tried helping me out but wasn't able to. One reason is it would be kind of a fail safe. And i like to be able to to raise the tps% a little so that I can stay in stoich if I'm
                            Not in boost. I know the v8's have tables for this. I did find in the ae enrichment tables. A table where u can command only a percentage of your commanded PE vs barometric pressure up to 105. So I might just work with that
                            • #29
                              Re: tiny tuner
                              Originally posted by ssms5411 View Post
                              I can send you a BIN. from my stock bin from hptuners if you want a 1997 bin. file.
                              Is it possible you could email me a copy of the stock 97 bin as well?
                              If so I will PM you my email address.
