OBX update ... I did not have any problems. The gasket fit corrcectly, the manifolds fit correctly. The only issue was the EGR hole in the manifold was too big to fit the stock screw. And I did not understand the spring for the header to y-pipe flanges. First heat up not leaks and everything was tight.
:rock:
Awesome to know - since mine are still in the box!
Robert - owner www.FirebirdV6.com"Mid-life crisis? I'm way beyond that!"
You need to get them on there Robert.
Went ahead and moved my starter wire from the back, to the front again since it had no effect on my drain on the battery. Also made me nervous driving...
5 hours ago
