Pinion Seal - FirebirdV6.com/CamaroV6.com Message Board
Pinion Seal
  • Pinion Seal
    I've been watching seepage from my pinion seal for nearly a year now. Now it has become a full leak, there is diff oil all over the underside of the car near the front of the diff, but no drips in the garage.
    I've got my haynes and I did some youtubing (theres a good video of a guy changing a pinion seal on a GMC) and I wanted to run a list of what I'll need to do the job by you guys, because I won't have a way to get to the parts store this time while the bird is out of commission.
    -New pinion seal
    -New pinion nut
    -Large socket for pinion nut (anyone know how big - 32mm? auto 2000 3.8L, no posi)
    -Chisel / grease pencil for marking pinion, nut, U-joint flange
    -RTV for pinon seal and flange splines
    -Torque wrench (in-lbf)
    -Puller to take u-joint flange off
    Anything else? Has anyone who has done one of these have any tips?
    Re: Pinion Seal
    Sounds about right.
      Re: Pinion Seal
      u sound like you got it covered. My mechanic did mine for free while it was on the lift for exhaust. I guess it is something kinda quick
      1997 Camaro LS1 RS
      1994 Camaro - Sold
      1999 Trans am Vert - Sold
      A Few Mods....
        Re: Pinion Seal
        Yea it seems simple. But there is the possibility of ruining the diff from under/over tightening the pinion nut at the end, so I thought I'd ask for any pointers. I'll take some pics and do a writeup while I'm at it.
          Re: Pinion Seal
          Just make sure you TQ the pinion bolt to spec.
            Re: Pinion Seal
            RTV?
            Use thread sealer on the splines of the pinion and yoke. The pinion seal doesn't require any RTV either.
            -<i>Travis</i><br /><b>99 Trans Am, Pewter, A4</b> Forged, stalled, and cammed<br /><b>85 Buick Regal WH1 T-Type</b> It\'d be cool if it ran...<br /><b>94 Camaro 3.4, Teal, M5</b> The daily beater
