Took me a total of a 1/2 hour or so but I was able to bend back the lower front fender brackets which made the fender line up nice with the doors. I went a head and removed the two 10mm bolts and the 1 plastic Philips screw underneath so I could pull the fender out a little. I pulled the fender out so I wouldn't scratch it plus it allowed me to get a better grip on the metal bracket. For safety I used some jack stands and placed them directly under some beefy steel bars (sub frame?). I also backed the car onto a few pieces of scrap wood to help raise it up a bit to be able to slide my floor jack underneath. The brackets were bent so bad that a socket wouldn't fit so I had to use a small wrench. I didn't have any vise grips so I used the biggest pliers I had [img]graemlins/naughty.gif[/img] The brackets bend fairly easy so it didn't take long.
Update! Bent front fender brackets fixed
by ssms5411Well my iPhone 11 Pro Max took a dump, it’s in a boot up loop, will try and get it fixed and give it to my mom. So I got a new iPhone 15 pro max, everything...1 week ago
by ssms5411So I’m still leaking coolant, I think it’s my front cover, going to double check when it’s alittle warmer, got the Zzp extra thick timing cover...2 weeks ago
by transamtom1Local car on a small lot just over 100k mikes(178,000 kms)
Silver with grey leather and black top 3.8L for $5400 cdn or $3975 usd as is....3 weeks ago
