FirebirdV6.com/CamaroV6.com Message Board
Go Back   FirebirdV6.com/CamaroV6.com Message Board > Technical > General Tech
Notices
Reply
Thread Tools Display Modes
Old 04-29-2006, 08:21 PM   #1
3.8L Strong
Lookin' for 13's
Default 98 Camaro Evap Orifice Location
Does anyone know exactly where, on the intake manifold, that the evap purge solenoid line is hooked up to? This is for a 98 Chevy 3.8 3800 Series ll V-6 engine. Also, exactly where is the orifice in that system located? Thank you for your support, Tommy.
3.8L Strong is offline   Reply With Quote
Old 04-29-2006, 08:35 PM   #2
BLLDOGG
ASE GM Tech - Moderator
BLLDOGG's Avatar
Default Re: 98 Camaro Evap Orifice Location
are you looking for the part you can plus something into like a machine? its ont the driver side with a green cap.
__________________
BLLDOGG is offline   Reply With Quote
Old 04-29-2006, 10:07 PM   #3
3.8L Strong
Lookin' for 13's
BLLDOGG, I have installed a Chevy 3.8L V-6 from a 98 Camaro, into my 2002 PT Cruiser. So, I'm actually piece mealing the evap system together to the specifications of the 98 Camaro. That's why I don't know exactly where these items are located at. I know from research that one of the evap lines runs from the vapor canister at the rear of the car, and goes to one side of the purge solenoid valve located near the number # 2 fuel injector on engine, and the other end comes out of the purges solenoid and goes to the throttle body. I'm trying to find out exactly where the orifice is located. I think it is installed somewhere between the vapor canister and the purge solenoid valve. Also, there is one more evap line that runs from the vapor canister to the leak detection pump, and from the leak detection pump it runs forward and connects somewhere at the intake plenum. I need to know exactly where that is? You can check on my conversion project by clicking on this link. http://ptcruiserworld.tenmagazines.c...ry.ten?id=3504 I have well over 100 pictures with documentation. I hope someone will be able to get the information I need. Thank you for your support, Tommy.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2016, Jelsoft Enterprises Ltd.
2001-20011 FirebirdV6.com/CamaroV6.com
Page generated in 0.12527 seconds with 8 queries
