FirebirdV6.com/CamaroV6.com Message Board
Go Back   FirebirdV6.com/CamaroV6.com Message Board > Technical > General Tech
Notices
Reply
Thread Tools Display Modes
Old 01-08-2007, 07:37 PM   #1
Big Tymer
Here to Stay
Big Tymer's Avatar
Default CALLIN BLLDOG! DTC P1860 TCC PWM Solenoid Circuit Electrical
So I had my car scanned and I got this
a little reaseach and I found this:
"Output operation: Torque Converter Clutch Pulse Width Modulated Solenoid (TCC/PWM)
The PCM uses the TCC/PWM solenoid to control when the torque converter clutch applies and how soft or harsh the TCC apply feels to the customer. The TCC/PWM also controls the release feel of the torque converter clutch. "
So is this doable in my own garage or is this something im gonna need to take in somewhere?
Big Tymer is offline   Reply With Quote
Old 01-09-2007, 01:00 PM   #2
CDNFB
Track Member
Default Re: CALLIN BLLDOG! DTC P1860 TCC PWM Solenoid Circuit Electrical
OK, I'm not BLLDOG, but here's some stuff I dug up.
TCC PMW solenoid is used to control fluid flow acting on the converter clutch valve.
The Solenoid controls TCC apply and release.
The Solenoid is attached to the transmission valve body. To get to it you have to remove the tranmission oil pan. Changing it should be no problem.
But do you need to replace it? To determine that you have to figure out if it is the wiring that goes to the solenoid or if the solenoid itself is shot.
Ignition voltage is supplied directly to the solenoid through a fused circuit. The Powertrain control module commands solenoid on or off by applying or removing the ground.
DTC P1860 is set if PCM detects a continuous open or short to ground in the TCC PWM solenoid circuit.
If your inclinded to attempt to fix this yourself, I have some trouble shooting proceedures that you can use. They are very involved, and could require the trans oil pan to be removed to get access to the solenoid.
If your not up to that, take it in to get it fixed.
CDNFB is offline   Reply With Quote
Old 01-14-2007, 02:46 PM   #3
Big Tymer
Here to Stay
Big Tymer's Avatar
thanks CDNFB ;-)
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2016, Jelsoft Enterprises Ltd.
2001-20011 FirebirdV6.com/CamaroV6.com
Page generated in 0.11972 seconds with 8 queries
