Back Pressure Myth - FirebirdV6.com/CamaroV6.com Message Board
Back Pressure Myth
  • Back Pressure Myth
    Not sure if anyone posted this, so I decided to. I found it on a civic forum and it explains it very well.
    Backpressure: The myth and why it's wrong.
    I. Introduction
    One of the most misunderstood concepts in exhaust theory is backpressure. People love to talk about backpressure on message boards with no real understanding of what it is and what it's consequences are. I'm sure many of you have heard or read the phrase "Hondas need backpressure" when discussing exhaust upgrades. That phrase is in fact completely inaccurate and a wholly misguided notion.
    II. Some basic exhaust theory
    Your exhaust system is designed to evacuate gases from the combustion chamber quickly and efficently. Exhaust gases are not produced in a smooth stream; exhaust gases originate in pulses. A 4 cylinder motor will have 4 distinct pulses per complete engine cycle, a 6 cylinder has 6 pules and so on. The more pulses that are produced, the more continuous the exhaust flow. Backpressure can be loosely defined as the resistance to positive flow - in this case, the resistance to positive flow of the exhaust stream.
    III. Backpressure and velocity
    Some people operate under the misguided notion that wider pipes are more effective at clearing the combustion chamber than narrower pipes. It's not hard to see how this misconception is appealing - wider pipes have the capability to flow more than narrower pipes. So if they have the ability to flow more, why isn't "wider is better" a good rule of thumb for exhaust upgrading? In a word - VELOCITY. I'm sure that all of you have at one time used a garden hose w/o a spray nozzle on it. If you let the water just run unrestricted out of the house it flows at a rather slow rate. However, if you take your finger and cover part of the opening, the water will flow out at a much much faster rate.
    The astute exhaust designer knows that you must balance flow capacity with velocity. You want the exhaust gases to exit the chamber and speed along at the highest velocity possible - you want a FAST exhaust stream. If you have two exhaust pulses of equal volume, one in a 2" pipe and one in a 3" pipe, the pulse in the 2" pipe will be traveling considerably FASTER than the pulse in the 3" pipe. While it is true that the narrower the pipe, the higher the velocity of the exiting gases, you want make sure the pipe is wide enough so that there is as little backpressure as possible while maintaining suitable exhaust gas velocity. Backpressure in it's most extreme form can lead to reversion of the exhaust stream - that is to say the exhaust flows backwards, which is not good. The trick is to have a pipe that that is as narrow as possible while having as close to zero backpressure as possible at the RPM range you want your power band to be located at. Exhaust pipe diameters are best suited to a particular RPM range. A smaller pipe diameter will produce higher exhaust velocities at a lower RPM but create unacceptably high amounts of backpressure at high rpm. Thus if your powerband is located 2-3000 RPM you'd want a narrower pipe than if your powerband is located at 8-9000RPM.
    Many engineers try to work around the RPM specific nature of pipe diameters by using setups that are capable of creating a similar effect as a change in pipe diameter on the fly. The most advanced is Ferrari's which consists of two exhaust paths after the header - at low RPM only one path is open to maintain exhaust velocity, but as RPM climbs and exhaust volume increases, the second path is opened to curb backpressure - since there is greater exhaust volume there is no loss in flow velocity. BMW and Nissan use a simpler and less effective method - there is a single exhaust path to the muffler; the muffler has two paths; one path is closed at low RPM but both are open at high RPM.
    IV. So how did this myth come to be?
    I often wonder how the myth "Hondas need backpressure" came to be. Mostly I believe it is a misunderstanding of what is going on with the exhaust stream as pipe diameters change. For instance, someone with a civic decides he's going to uprade his exhaust with a 3" diameter piping. Once it's installed the owner notices that he seems to have lost a good bit of power throughout the powerband. He makes the connections in the following manner: "My wider exhaust eliminated all backpressure but I lost power, therefore the motor must need some backpressure in order to make power." What he did not realize is that he killed off all his flow velocity by using such a ridiculously wide pipe. It would have been possible for him to achieve close to zero backpressure with a much narrower pipe - in that way he would not have lost all his flow velocity.
    V. So why is exhaust velocity so important?
    The faster an exhaust pulse moves, the better it can scavenge out all of the spent gasses during valve overlap. The guiding principles of exhaust pulse scavenging are a bit beyond the scope of this doc but the general idea is a fast moving pulse creates a low pressure area behind it. This low pressure area acts as a vacuum and draws along the air behind it. A similar example would be a vehicle traveling at a high rate of speed on a dusty road. There is a low pressure area immediately behind the moving vehicle - dust particles get sucked into this low pressure area causing it to collect on the back of the vehicle. This effect is most noticeable on vans and hatchbacks which tend to create large trailing low pressure areas - giving rise to the numerous "wash me please" messages written in the thickly collected dust on the rear door(s).
    VI. Conclusion.
    SO it turns out that Hondas don't need backpressure, they need as high a flow velocity as possible with as little backpressure as possible.
    Re: Back Pressure Myth
    good read!
    1999 v6 Camaro M5
    Automatic to Manual converted
    Pacesetter Headers, 2.5" Custom True Duals with X-Pipe and Magnaflow Bullet Muffers,
    !cat, Intake, 3.42's with LSD, MSD Wires, Drilled/Slotted Rotors, Hurst Short Shifter, Tuned PCM
      This is a good article. Should give some people a better understanding. Damn, I was thinking about going with a 10" exhaust and jamming a basketball in the end for backpressure.
        not fun , but here it is a pic of Corvette with this system installed: Check it out !
          what does that have to do with this?
            what do you mean? Its a real working system that creates backpressure at low RPM
              ahh, the system of low RPM backpressure and more flow in the high RPM's. Gotcha. But if you hadn't noticed, the whole thread isn't about this system, so it wasn't clear what you were getting at. Sorry, got it now :tup:
                This is why you see cars with big turbos with like 6 inch exhaust. The actually loose alot of power when not boosting because the have absolutley no back pressure. But once peak boost hits you are moving alot of air, hence the back pressure is substantial and they are pounding power to the pavement. On our cars you actually loose horsies cause of a 3 inch, but not much and you gain Torque
                  Got a dynosheet that shows a decrease in peak HP and area-under-the-curve?
                    I was about to say that...x2
                      I shouldn't of even said that thing at the end.... I was mainly talking about the turbo's and the exhaust. I saw a wrx at napa the other day with no lie a 6 inch exhaust and this is because of when peak boost hits you are moving a lot of air, meaning back pressure is high... I will look for that dyno sheet though:)
                        You do not loose torque or hp from a 3" exhaust. very plain and simple.
                          Yea, If you lost horsepower and torque with a 3-inch exhaust...why would people use cutouts when they're at the track? That would be even less back pressure right?
                            right
                              Maybe I can link to a class on fluid flow.
                              Exhaust systems for street cars are always a compromise, since the exhaust flow is never steady state. As the article says, you want maximum flow with the least backpressure (which is due to the resistance of the piping - surface roughness, diameter, etc), but that point varies with RPM.
                              No one is right, or wrong.
                              http://www.pipeflowcalculations.com/airflow/index.htm
