wow... a superchager with fairly low miles for just over 1k? now thats what im talking about :banana:, too bad i still can't afford it, otherwise i would be all over this
So, that would bolt right up to our LIM after some cowl work? Could you maybe get some dimensions on it, that way people know how much work they're in for.
Negative, thats why you need the L67 LIM. The L36 has the injectors in the LIM, correct? They L67 has the injectors in the head, hence the heads are for sale in this too. You will be swapping out your UIM, LIM, and heads with the m90, L67 LIM, and L32 heads. This will also mean the L67 fuel rail is needed, which I will post pics of tomorrow.
Searching top swap or something along those lines will show you with results on clubgp. Thats what this is essentially.
Wow, I always wondered about you and your project. But I see your selling it now. It's quite a bargain seeing how much work you've put into it already.
People should jump on this and make it their project.
